westy
Hello everyone.
I have a question about ball nuts.
The image is a 242B Seafoam ball nut, but I saw the groove indicated by the arrow for the first time. What is this difference? Mistake in the factory?
Thank you,
Junichi Click image for larger version - Name: IMG_7798 - コピー.jpg, Views: 184, Size: 198.95 KB Click image for larger version - Name: InkedIMG_7799 -Ball nat.jpg, Views: 194, Size: 127.56 KB
Mister Wilson
I don’t know.  My A46 all seafoam has the smooth edge.
i have a few nuts like that too .
Newfie
Those globe designs are really nice.
i have some regular splined 220 ball nuts done the same way , top n bottom , by the way OCP sells em nos for like 4 bucks as i recall
Ball Nut Splined 220
I have a few of those too. They may have been  packaged parts for replacement, as some of them came in the little bags right from Toronto.
i have been looking for this same information for years now , still scratching my head LOL all i found was the matching 220 style . they all seem to come from Canada . the first one i got was in a 242K so im thinking these are early but i duno anything for sure here .
Click image for larger version - Name: InkedIMG_7799 -Ball nat.jpg, Views: 21, Size: 127.56 KB
westy
Thanks everyone for the response. Maybe the first lot came with a lot of Canadian-made 242A, B lanterns, or it could be a replacement. It is a great discovery for me. The same ball nut was from Canada. Thanks for posting the Steve photo.
Guff
Yep, I think it's a Canadian thing, and not confined to Canadian seafoam painted lanterns, or any particular models.
I went and checked all my Canadian 242, 247, and 249, and Australian 242B and 249 series lanterns, with that style of vent nut, and found about 20 vent nuts out of 60 lanterns without the vertical striations on the bottom flare. That vent nut type appeared sporadically across that range of lanterns, but with no defined pattern.
I also found some of the ball type vent nuts on both Canadian and USA lanterns without the bottom striations as well, and some with them. Again no pattern emerged, between models.
Here is a pic of some.
Keith.
westy
Keith.
Hello Keith,
Thanks for the reply. Thank you for the attached photo. It is very easy to understand. There were also 247,249 series other than 242B, but there is certainly no definition. Neither 247 nor 249 in Canada I have has vertical striations on the bottom flare. It is very interesting.
_____
I am looking for a Canadian model L427😃
Thank you,
Junichi
I've seen others as well. especially on Canadian lanterns.
Any spares?
“Solo sé que no sé nada”
here are a few more i got out of Canada .
[20200811-152724]
Any spares?
That’s pretty funny. Parts may be harder to let go of than lanterns and lamps!
I frighten easily!
ya , i answered Pancho in a PM , i only have 2 of the knurled top n bottom 242 nuts and there on lanterns , not available !!!
westy
Wow!! Thank you. I also saw Steve's ball nut for the first time😃
The mystery deepens.
@SteveRetherford are those ball nuts for a 242b also? If they are I have never seen one then
no , those are 220 , 228 , 236 , 237 style , and a host of others but Canadian .  common size , but not common knurling .
Thank you Steve 👍
some of those were sold as replacements in Canada-they came 2 to a pack and had the spline knurl on the lower flange.
westy
Thank you for contacting me. I was convinced.
MYN
I may be wrong for this specific case but the additional straight knurling on the lower flange is not a surprising thing.
I've had similarly shaped and knurled brass ball nuts being machined in a local machine shop here. Its actually easier for the machinist to make the tiny piece with the knurling all the way length-wise and cutting the groove after that, rather than having the upper side knurled but leaving the bottom flange smooth. One of the reasons: clearance of the knurling tool from a rotating chuck can be troublesome or tricky since you can't leave too much extension on the relatively small-diameter brass stock out from the jaws of the chuck during a high pressure knurling process.
Dean would know this very well.
