BobA
Project 459
In this project, we will go through the Coleman Model 459-499 stove. Made from late 1977 - early 1978, this is probably one of the rarest of the Coleman stoves. More information is available on my other post, 459 - Theory of Operation.
I just want to point out that, on this stove, because of its rarity, I've decided to keep as much of the original finish as possible. This stove was well-used, and had a good amount of spillage into it which was not cleaned and, therefore, turned to rust. It also had some dried duct tape residue in various places. If this were any other "suitcase" stove, I would have at least, attempted a touch-up, or perhaps even stripped it down for a re-paint! However, on this one, I just removed the rust and cleaned it up as best I could, while keeping it original. So, the end result may not be as pretty, but it is honestly original!
Here are some photos of the stove, as I received it.
The first step is to remove the lid. Do this by depressing one of the hinges toward the center, until it clears the hole in the case. Then lift out the lid.
To remove the grate, work out one of the clips (incredibly tough & tedious job), and lift out the grate. Then slide the grate out of the other clip & remove.
Now, remove the screw & clip holding the manifold to the back of the case.
From the bottom of the case, remove the two (2) pal nuts holding the manifold to the drip tray. Hold the manifold in place until removal, since it will want to fall out if you move the case.
Turn the auxiliary burner valve, so that it aligns with the slot in the case, as shown.
Lift the entire manifold assembly out of the case.
Remove the two (2) screws on both sides of the case (4 total), securing the drip tray.
Lift out the drip tray.
Now, we dismantle the burners. Starting with the main burner, remove the screw that holds the burner together.
Lift off the burner cap.
Remove the rings...
...and the baffle plate.
Removing the burner bowl completes the disassembly of the main buner.
We do the same thing for the auxiliary burner. The only difference is that this burner does not have a baffle plate.
Here are all the burner parts, ready for cleaning.
After cleaning the parts, it's time for re-assembly. Here is the manifold.
We'll start with the auxiliary burner. Place the burner bowl on the burner.
Lay on a flat ring...
...followed by a wavy ring.
Continue to alternate rings, ending with a flat ring. This burner has 7 rings - 4 flat, and 3 wavy rings.
Now place the cap on top of the rings.
Insert the screw, and turn down finger tight.
Using your fingers, center the rings vertically.
Now tighten the screw snugly.
Re-check the rings to see that they are centered. If not, loosen screw and repeat.
The completed auxiliary burner.
Place the burner bowl on the main burner.
Now, install the baffle plate.
Install a wavy ring. Note that the baffle acts as the first flat ring - this is why we start with a wavy ring.
Install a flat ring.
Continue to alternate rings, ending with a flat ring. This burner has 6 rings - 3 flat, 3 wavy (not counting the baffle).
Install the burner cap.
Install the screw, center the rings, and tighten, as you did before.
The completed burner assembly.
Now we move to the most interesting part of this stove - the tank & valve.
First, we remove the pump. Straightforward stuff.
Since I didn't want to gouge up the generator, I first applied friction tape, then used leather to grip and loosen the generator, as shown. Loosen only at this time. Do not remove.
To remove the knob, note that there is a clip behind the knob that must be depressed. Depress it with a small screwdriver, and work the knob off the valve stem.
At this point, place the valve body in a vice and hold snugly. Twist the tank evenly to loosen it from the valve. Now remove from the vice and unscrew the valve from the tank, counting the number of turns until removal. You will need that count when you re-install the valve.
The valve & generator, ready for disassembly.
You might wonder why I did not remove the generator before removing the valve from the tank. The reason for this is that, according the the stove instructions (particularly the parts list & exploded diagram), the valve stem and the needle are not separate, but are one part! At least, it gives the impression that they are one part. I found out after disassembly that this is not the case, and the needle does unscrew from the valve stem - like any other stove. But, I didn't know this at the time, so I thought it best to keep the needle well protected in the generator during disassembly, since I probably won't ever find another one!
So, put the valve body in a vice.
Unscrew and remove the generator tube.
Carefully slide the spring off the needle.
Using a 3/4" wrench, loosen the stem nut. This was on very tightly.
Unscrew & remove the nut. Be careful that you retain the internal parts (spring & washer) as they come out.
Loosen and remove the F/A tube.
Gently withdraw the valve stem & needle assembly.
Remove the F/A rod & spring.
Remove the spring from the stem nut.
You'll need to gently pry out the brass washer with a small screwdriver or other suitable implement.
Next, dig out (carefully) whatever is left of the o-ring. Be careful not to scratch or damage the stem nut.
Here is where I found out that the parts list/diagram was misleading. The needle does, in fact, unscrew from the valve stem, although, apparently, the two were meant to be ordered and replaced as an assembly. Why? Who knows?!
This is the front o-ring. It is what turns the fuel flow to the generator on and off. Both the front and rear (packing) o-rings are the same part number (5445-220) and are both square cut o-rings, size 010 (1/4" I.D. x 3/8" O.D. x 1/16" C.S.).
The front of the valve stem, after o-ring removal.
Now, remove the gas tip protector from the generator tube.
The gas tip was stuck inside the protector, so I tapped it out gently with a plastic mallet, and an old chop stick.
All the valve components cleaned & ready to go.
The two new o-rings.
Install one in the valve stem.
Install the second one in the stem nut. First, lay the ring squarely in the opening of the nut, as shown.
Using the spring, gently press the o-ring in until it seats properly in the nut.
Install the spring onto the valve stem...
...followed by the washer.
Gently insert the valve stem into the valve body.
Lightly lube the stem with some hi-temp silicone lube. This assures that:
a) the o-ring will more easily slide over the stem during assembly, and be less likely to bind & twist.
b) the stem will slide in & out easily, as it needs to, during use.
Carefully slide the stem nut over the valve stem, being careful not to damage the o-ring. Then tighten finger tight.
Place the valve body in the vice and tighten the nut tightly.
Looking into the inlet of the valve (F/A tube port). Turn the valve stem to center the OFF detent in the port, as shown.
Place the F/A rod & spring into the tube, as shown.
Screw the F/A tube into the valve body. IMPORTANT - the F/A tube must meet the valve body, as shown in the 2nd photo below, without using force of any kind.  When done correctly, it goes in fully - finger tight. If there is ANY resistance, twist the valve stem slightly back and forth, until you can finish seating the tube without force.
Failure to follow this procedure could result in damage to the F/A tube and/or the cam of the valve stem - both of which are irreplaceable!
Tighten the F/A tube snugly.
Insert the needle into the valve, engage the threads of the valve stem, screw in and tighten finger tight.
Using pliers, tighten snugly. Do not overtighten!
Install the spring over the needle.
Install & tighten the generator tube.
Insert the gas tip into the end of the generator tube.
Install & tighten the tip protector.
The assembled valve & generator.
Apply a small amount of thread sealer (I like Permatex #2) to the valve body threads...
...and screw it into the tank (the same number of turns that you unscrewed it earlier). You'll probably need to mount the valve body in the vice to finish tightening.
Insert the air stem...
...and install the pump.
Install the fuel cap. Mine was in great condition and didn't need to have the gasket changed.
Sliding the knob on the valve stem completes the tank and valve assembly.
Now, we re-assemble the case. First, install the drip tray into the case and align the holes.
Install & tighten the 4 mounting screws (2 on either side).
Align the auxiliary burner valve with the slot in the case, and insert the valve through the slot.
Install the manifold/burner assembly on the drip tray.
While holding the manifold in place, install & tighten the pal nuts from the bottom of the case.
Install and tighten the screw & clip holding the manifold to the back of the case.
Install the grate by sliding one end into the clip, then the other end, working the clip into the case, as shown.
Now, replace the cover by sliding one hinge into the hole at the rear side of the case. Then depress the other hinge toward the center while working it into the hole.
The completed stove case.
The finished stove, with tank & valve in place.
Now, we light 'er up. We turn the knob to the LIGHT position and light the burner.
After about a minute, turn to the HI position.
Here is the LOW setting. A nice simmer.
Open the auxiliary burner valve. Here are both burners on LOW.
Both burners on a medium setting (halfway between HI and LOW)
Both burners on HI.
I did the "boil a quart of water" test on the main burner. Achieved a hard boil in 3:01 (three minutes, one second)!
This thing works great!
Well - looks like we've come to the end. Be happy and safe!
BobA
Kansas John
Thanks for all the work documenting the operation and tear down of this stove, Bob! Very thorough and informative.
John M. Lawrence, KS
ICCC #1431
You do a good write-up, Bob.  Remind me in a week or two and we will get this put into the Tech archives.
BobA
Thanks, guys!
