Mister Wilson
I have what I believe to be an Akron 125 lamp with 6" diameter fount (crappy flash chrome) and Instant-Glo burner.  It was made for Montgomery Ward, so there may be a different model number.  Moses recent post inspired me to get going on it.  I've run into a couple of issues and have questions.
At some point the tip cleaner lever was bent to a 90.  I'm reluctant to try to straighten it because it's steel and rusty, but works as is.  I would like to remove it, but there is a lot of resistance.  Would this be about as advisable as removing a 200A tip cleaner? :-)
I'm hopeful the generator is in good condition.  The pricker is shown as it looked when removed, very clean.  I can look up through the generator and see light through the tip orifice, but I would like to remove it if possible.  It appears as though it doesn't come apart, is that the case?  To the left of the generator is the interesting instant start parts.  That brings up my predicament.
Before I tore it down, I tried to pump air into it..  Fresh cap gasket, no visible fount cracks, couldn't get it to even hold the slightest bit of air.  Now I know why!  Pickup tube has a long crack in it. Does anyone know if this tube will unscrew from the bung?  I can try to carefully solder the crack, but I don't know if it extends past the bung into the fount, and I'd like to see what the bottom end looks like to fully understand how the instant lighting works on this thing.  I think air passes through the outer tube and fuel through the long thin tube, but I'd like to see the other end to know for sure how it all comes together.
Thanks in advance for any help, advice, cautions...
Mister Wilson
Calling all Akron experts.  Lol!
Erwin
It seems I had unscrewed the pick-up tube at least on one lamp: LINK
Good luck with your lamp.
Mister Wilson
Thank you Erwin, this is very helpful.  The tube looks like it should unscrew, but I didn’t want to make matters worse.  I see the tip cleaner stem was bent on your lamp also.  Your lamp turned out very nice, love the finish on the fount.  Again, thanks for the help!
Erwin
John, the lever was bent some and I very carefully bent it back in the almost correct position.
The finish is original. It came from the factory that way.
The other lamp had almost nothing of the original paint left. Hence I had repainted it.
Hope your project comes out nice.
Happy fettling, Erwin.
