Reply
  Author   Comment
wpnaes
Avatar / Picture
Over
500 Posts!
Reply with quote  #1
I found one.[sHa_yes2]
Does anyone know the fitting size to connect it to a lp bottle?
__________________
Sean
Coleman 275 Turd Herder #063   Brotherhood of the Traveling Lantern Host #002
Brotherhood of the Traveling Sears Host#001   Sears Collectors Club #004
BernzOmatic Appreciation Club #063   The Coleman Blues 243's #263 MilSpec #0263
StanDahl
Avatar / Picture
Reply with quote  #2
I don't know the fitting size, but the little stove adapter works, check this auction.
__________________
vette_boy
Avatar / Picture
Over
500 Posts!
Reply with quote  #3
Sean you lucky duck I've been looking for one of those for a long time !!
__________________
Dave
Now ICCC Certified !!!! # 1693
Just waiting for a power outage
dpatten
Avatar / Picture
Help! Help!
I'm being repressed!
Reply with quote  #4
There's not a lot to that.  I bet there would be a smallish market of guys that would buy them if someone built them.
__________________
Dennis the Peasant
-R.A. Heinlein-
rangler
Turn and Burn
Reply with quote  #5
I bet there would be too. The question would be whether the time/material costs would result in a retail price that would be considered "affordable".
__________________
---Randall----ICCC member #1143---
wpnaes
Avatar / Picture
Over
500 Posts!
Reply with quote  #6
A few more pics of the adapter all shined up.  The stamped steel flange is soaking in EvapoRust.  The inside part of adapter is a 2 piece brass unit with a rubber insert that wraps around the needle on the lantern.  The outer part is a simple brass fitting (I need to head to the hardware store to find a male match and connect that to a hose).
The middle is galvanized pipe.  Looks like they used a thread sealer to boot.
__________________
Sean
Avatar / Picture
The Flashlight Man
Reply with quote  #7
Make sure the rubber in the adapter is crack free as that would be a cause for a leak. I own #2 of these adapters and it allows me to run both of my 5120 and 5122 off of a bulk tank if needed...campinut...
__________________
wpnaes
Avatar / Picture
Over
500 Posts!
Reply with quote  #8
Got working on the 5122 again.  When I removed the manifold, broke all 3 screws.  So drilled and tapped for some M4-07 screws and got her hooked up again.  Now just need to build an adaptor/hose for some propane.
Yes Thien, that's your 242 Seafoam lurking; just got a round tuit today!
__________________
Sean
wpnaes
Avatar / Picture
Over
500 Posts!
Reply with quote  #9
Wondering if someone here won the 5122 LP adapter Mike was selling.
https://www.ebay.com/itm/COLEMAN-LP-LANTERN-CONVERSION-KIT-/312464265614?_trksid=p2047675.m43663.l10137&nordt=true&rt=nc&orig_cvip=true
If so, could we get some dimensions on the hose adapter?
Name: BB1C783E-15D3-4932-AFFE-F06F0C06C8CA.jpeg, Views: 58, Size: 57.82 KB
__________________
Sean
warren
Reply with quote  #10
That went cheap.
__________________
ANTIQUESWV on Ebay
#1 in the 223B club
Gatlinburg, TN
Avatar / Picture
Keep Trying
Reply with quote  #11
Yeah cheap for a NOS and very uncommon item these days.
__________________
Nomo reoil
Reply with quote  #12
I've got a full original setup, see my posts for pics, what dimensions are you looking for?
Ryan
__________________
Fettle today for a brighter tomorrow!
wpnaes
Avatar / Picture
Over
500 Posts!
Reply with quote  #13
Thanks Ryan, I’m looking for dimmensions of the female hose fitting that attaches to the ‘canister adapter’ male end protruding lantern door where the LP can would sit.
I tried Russ’s method without success - see pic below.
It seems a special bevel is needed for a leak free fit. I tried the hose gasket, but still had a leak.
Name: 4B11B125-71DB-444E-BD60-38DE73E97FAE.jpeg, Views: 59, Size: 83.61 KB
__________________
Sean
Nomo reoil
Reply with quote  #14
Here's the original female fitting end.  I looked for a way to make this end from purchased parts or find something else that used it with no success.
The seal is not in the threads but an o-ring. Without this end I think the brass end on the converter would need to be changed to work with a currently available hose fitting. coleman lp hose end.jpg  rsz_img_1070.jpg
__________________
Previous Topic | Next Topic
Print
Reply
Quick Navigation:
