Reply
  Author   Comment
FishGutZ
Definite
Reply with quote  #1
Since a CQ lamp has a straight pick up with no F/A tube ,the valve is either on or off with no real metering? The generator office is only allowing so much fuel into the mixing chamber. So my question is would a 1/8npt valve work as a replacement ,I've been building some Frank's lately ,could not find much in my search of the archives as far as this question relate.
Thanks in advance
__________________
......ASA....
Avatar / Picture
So many stoves,
so little time
Reply with quote  #2
I'll ask, is the original defective? What are wanting to accomplish? Genny tip can be replaced.
__________________
FishGutZ
Definite
Reply with quote  #3
No I guess just a question that popped into my head , the valve does not hold 100% but I need to give it a soak in some carb cleaner , but I could put the valves in line of each other so I did have a positive shutoff and then be able to put the genny in
__________________
......ASA....
FishGutZ
Definite
Reply with quote  #4
Generator is new , I guess I was asking if the genny tip on a straight pick up is what meters the amount of fuel being dispersed,
__________________
......ASA....
Avatar / Picture
So many stoves,
so little time
Reply with quote  #5
Genny tip has the final say, that effects output. That would be a different frankie, two valves.
__________________
FishGutZ
Definite
Reply with quote  #6
10/4 thankyou
__________________
......ASA....
JohnnyMac
Avatar / Picture
Over
500 Posts!
Reply with quote  #7
When I was in my "Franken' phase" a couple of years ago, I tried to find valves with 1/8 NPT threads, that could be used for CQ fount-based projects. Maybe my Google-Fu was not strong enough, but I couldn't find much, except very expensive models used in laboratories and chemical manufacturing.
__________________
Accidental Member of the 237-B Club
"When all else fails, turn it into a Frankie!"
Lancaster Lanterns 400 CP "Toasted Retinas" Club
"Why would someone make a 1000 CP lantern?  Because they CAN!"
Northman49
Avatar / Picture
Over
500 Posts!
Reply with quote  #8
Google-fu works. Ball valves are better than gate valves.
https://www.amazon.com/s?k=1%2F8+npt+ball+valve+brass&crid=1LVIFA40JGHQ5&sprefix=1%2F8+NPT
__________________
                 CANADIAN BLUES Member #023
FishGutZ
Definite
Reply with quote  #9
I work for a mechanical contractor , they have plenty of material for Franken projects ,
__________________
......ASA....
Avatar / Picture
Super Poster
Reply with quote  #10
I like the looks of this one better:
But I'd worry about the valve handle getting too hot to touch. CQ valve wheels get pretty warm, and they stick out a ways from the valve.
__________________
Previous Topic | Next Topic
Print
Reply
Quick Navigation:
